97-99 OEM Stanley Headlights Flawless 10/10 took off a 99 Spyder with 32K miles and had headlight covers on it the entire time since new. No fading, clear coat peel, or hazing. Never will see another set like this. Absolutely Perfect. SOLD
99 GSX 5spd Non Eprom ECU. Had this in my GST to ditch the speed limiter because of the H rated tires. Never took advantage of it, so here it is for sale. I also have a 97 GSX 5spd ECU somewhere, should be the same. SOLD
95-99 2G DSM Power Antenna Assembly removed from a 1997 GSX SOLD
95-99 Greddy 24R FMIC with all pipes. This kit will allow you to retain your stock fog lamps and bolts up in all factory locations. I will include silicon couplers and I replaced all the clamps with T Bolt clamps that will be included with the kit. This kit is in very good shape. SOLD
95-99 Greddy Upper and Lower IC pipes. Flanged for a Greddy BOV, it is great shape as well. I will include all couplers and clamps that came with the kit. $150
95-99 Sarrona Red Drivers Fender, perfect replacement for your dinged, scuffed, or faded one. $75
95-99 Sarrona Red Gas Door, perfect replacement for your dinged, scuffed, or faded one. $30
95-99 Clear Corner Lamps, perfect shape $20
97-99 Eclipse Reverse Lamp. $10
95-99 2G Turbo K&N Filter with Adapter. I just cleaned it and would be happy to re-oil it for the new owner, but it will be messy, so I have not done it yet. $50
95-99 2G Non-Vented rear brake rotors. Brand New never installed. I will also include a set of EBC Red brake pads with 75% life left. $50 for all
