I have for sale a pair or front 30mm front Z32 calipers w/ brembo drilled rotors and mystery used jdm pads that will most likely need replacing shortly
Caipers are off a Z32 front JDM clip and came with whateva pads are in them now
I baught the rotors new just over a yr ago and had them driled to 4 bolt
What you are buying
-Z32 30mm aluminum calipers
-well used mystery pads that came in calipers
-z32 30mm Brembo cross drilled rotors drilled for 4/5 bolt
$550.00
Baught these off samson
