1985 S-10 Blazer
189k Miles
2.8 V6, 5-Spd, 4x4
Located in Butler, PA @ JTech Sales & Service
Price: $550 (firm)
Contact
You can call me at 412-916-3262, though if you want to actually see the truck you can call JTech at 724-284-8324.
Info
Bought this a while ago because I wanted it for winter, but I have half a dozen projects that are ahead of this and I won’t get to it before snow falls.  It starts right up and the motor sounds fine.  As you can see the body is hurting, though the truck was Ziebarted, so the rocker boxes on the cab are actually real clean.  Worst part of the body (IMO) is above the rear window, as the hinge attachment point is gone.  Former owner just used putty but bottom line is it needs some steel welded in there.  Frame looked good at a glance, though one front cab mount (the cup on the cab, not the frame attachment point) looks questionable.  All the body parts (including the cab mount cup) are cheap and easy to get from LMC Truck or Parker Metal Products up in Tarentum.
Needs
Clutch (or maybe just a slave?  I literally haven’t touched it)
Body work
FAQ
Will the truck drive?
No.  The clutch is totally non-functional.  Could be as easy as a slave, could need a whole clutch kit, I do not know and don’t plan to find out.  The truck starts and runs but will not move itself.  It does roll freely as 2 of us pushed it around the lot at JTech so nothing is frozen up.
Will you part this out?
Not yet.  If it’s still around in a month then I’ll consider it.
Are you interested in trades?
Not especially, as I have enough projects, but it’s possible.
Is the price negotiable?
No.  I have more than that in the truck, I’m just cutting my losses.
Do you have the title?
Yes.  The clear title is currently held by JTech under the dealer license and Jason can transfer the title to you at the local notary, which is 2 minutes away.
Can you deliver the truck in the area?
You can arrange flatbed delivery with Jason @ JTech.  You will have to discuss the rate with him.
.JPG)
.JPG)
.JPG)
.JPG)
.JPG)
.JPG)
.JPG)
.JPG)
.JPG)
.JPG)
