Alpine PDX-1.1000 Amplifier - NEW!
I am selling a new Alpine PDX-1.1000 Amplifier. I took the amp out of the package to hookup once and put it away. It is an amazing piece, do some research and you will see. Makes loads of power (tested to over 1166watts RMS) in a TINY size, producing excellent sound quality.
Specifications:
- mono subwoofer amplifier
- 1,000 watts RMS x 1 at 4 ohms & 2 ohms (tested to do over 1166 wrms!!!)
- variable low-pass filter (50-200 Hz, 24 dB/octave)
- Class-D amplifier design
- stackable installation design with front-panel controls
- quick-connect speaker connectors
- preamp-level inputs and outputs
- CEA-2006 compliant
- fuse rating: 20A x 4
- 10-3/16"W x 2-1/2"H x 8-7/8"D
This amp retails for $1150 CDN, however I am asking less than 1/2 of that!
Asking $485.00 CDN.
Alpine 9887 MP3 CD Head Unit - Excellent Condition
This headunit is a return to Alpine’s glory days. Alpine’s best-sounding CD receiver, the CDA-9887, includes an impressive digital sound control “tool box” — you get an incredible degree of control over the way your music sounds. The receiver produces the best possible sound from your CDs, thanks to its premium Burr-Brown 24-bit digital-to-analog converter. I really do not want to sell this unit, so if it doesn’t sell for close to what I am asking for, it simply wont be sold. Its in excellent condition, used for a few months.
Specifications:
- CD receiver with built-in amplifier (18 watts RMS/50 peak x 4 channels)
- plays CDs, CD-Rs, and CD-RW discs, including discs loaded with MP3, WMA, and AAC
- fold-down, detachable face with a 2-line BioLite text display
- remote control
- 24-bit Burr-Brown digital-to-analog converter
- digital signal processor includes a 7-band equalizer (switchable to 5-band parametric mode)
- 6-channel digital time alignment, and high- and low-pass filters
- Alpine’s Imprint MultiEQ sound tuning technology
- compatible with: Alpine Bluetooth® adapter, satellite radio, HD Radio™ tuner, CD changer
- inputs: optional iPod control, optional aux input
- outputs: three sets of 4-volt preamp outputs (subwoofer output has bass level control)
Asking $315 CDN
JL Audio 300/2 Stereo Amplifier
I don’t really need to explain this amp - as many know JL Audio produces some of the best amps in the car audio world. Excellent sound quality, makes more power than rated for, high build quality, overall excellence. This particular unit is 9/10 condition (excellent condition).
Specifications:
- Rated Power : 150 Watts RMS x 2 @ 1.5~4-Ohms (11V-14.5V)
- Rated Power (Bridged Mono) : 300 Watts RMS x 1 @ 3~8-Ohms
- R.I.P.S. (Regulated Intelligent Power Supply)
- Absolute Symmetry Class A/B Circuit
- RealSink (Heat-Management System)
- Differential-Balanced Input Topology (1 Pair of Inputs)
- 12dB Crossover
- 24dB Linkwitz-Riley Crossover selection (Any DJ knows what this is, Linkwitz Riley is known to be the most accurate type of crossover ever!)
- Preamp Output : selectable as pass through, tracking LP or tracking HP
- Speaker Output Connection : accepts up to 8AWG wire
- +12V and Ground Connections : accepts up to 4AWG wire
- Left to Right Channel Separation : >75dB @ 1kHz
- Input Range : Switchable from 200mV-2V RMS to 800mV-8V RMS
- Dimensions (LxWxH): 13.4" x 9.25" x 2.36"
Asking $275
Alpine Type-R SPR-17S 6-1/2" component speaker system
I am selling my Alpine Type-R SPR-17S 6-1/2" component speaker system. These things sound excellent - clean smooth mids and high’s. I used them for a few months, and they are in excellent condition. One of the tweeter grilles isn’t included (I can’t find it), but that isn’t needed for most installs anyways. It comes with all of the other mounting hardware, screws, etc.
Specifications:
- system includes two 6-1/2" woofers, 2 tweeters, and 2 crossovers
- Power Handling Capacity (RMS): 110 Watts
- Power Handling Capacity (Peak): 330 Watts
- hybrid layered-pulp woofer with rubber surround
- 1" silk ring-dome tweeter
- external crossovers — 12 dB/octave (high -pass) and 6 dB/octave (low-pass) crossover points
- 7-level tweeter adjustment
- frequency response: 65-27,000 Hz
- sensitivity: 87 dB
- top-mount depth: 2-3/8"
Asking $250
If interested, send me a PM or e-mail me at paradigm905@hotmail.com . I prefer to meet in the GTA (downtown toronto during weekdays & brampton/mississauga during weekends/weeknights).
