Air compressor is the older model of the 180, but its barely used at all and in prime condition
AIRBRUSH -----Paasche MILLENNIUM - Siphon Feed Double Action - Internal Mix
The airbrush for now and the next 100 years features thin barrel grip and a cut-away red anodized handle that allows quick pullback of needle mechanism to blow out clogs. Round trigger button rollsunder your finger for greater comfort and better control. The MIL gives you the same great airbrushing results achievable with your Paasche VL airbrush. Optional color cup and bottle assemblies are available for larger volumes of paint.
MIL Spray Pattern 1/32"- 1 1/4" Medium Fluids
Recommended Air Pressure .5 to 1 CFM @ 20 to 45 lbs depending on type of fluid being sprayed.
ill take 60 for the compresor and 45 for the airbrush, airbrush was NEVER used
