Parts are currently in Japan and will be until sold. Prices are firm. Methods of payment are as follows: Paypal, interac direct email deposit, direct RBC deposit and or money order. Prices include shipping to your door. If you require faster shipping times, I will send it via EMS (express mail service) for an additional 15-20 Canadian.
Part: BLITZ ACCESS ECU for S13/CA18DET
Condition: Used Excellent Working condition
Contact: pm, msn> ford_edge@hotmail.com or adam@gatmotors.com
Price: $300 Canadian Firm
Extra’s: The ECU is setup for lightly to mildly modified engines and will give you higher boost throughout the power band and are simply referred to as a Boost UP Computer here in Japan (recommended use with boost controller). Along with the concept of boost up, the ECU has a more agressive fuel and ignition timing curve to allow best tuning while minimizing the possiblity of detonation. The REV limiter, speed limiter and boost limiter cuts are also standard with this unit. The actual vehicle that this was used on had light mods, full muffler, air intake, boost controller and the stock turbo and stock intercooler boosting at .8 bar.
next time you make up a story about an ecu for a sr20det you should take out the part about boost limiter and the ecu upping boost because there is no such thing and the ecu has nothing at all to do with boost control so this ecu will not increase your boost levels.
How do you always some how put your foot in your mouth?
SR, CA and RB ECU’s control the boost levels…
Why do you think when ever you get a full pull down engine set or a front clip
you are left with this knob type thing beside the ignitor? Thats the Factory
Boost Controller and that knob adjusts the boost curve from smooth to sharp…
Hey… lol, I never hooked up that little box which would be beside my ignitor for the Boost Curve Control you say ? IF i did hook it up would it increase boost pressure over 7psi or will does it only make the boost come on stronger / harder hitting ?
Im still learning alot about these cars/engines but if you dont mind answering a quick question for me I greatly appreciate it!
