hey guys…
I have a Carbonetic (ATS) 1.5 way carbon diff in an S14 pumpkin with an S13 backing plate with Nismo diff bushings installed.
This is a direct fit into S13 and all it would take to put into S14 is a new rear cover… it is an S14 diff that i changed the cover on.
It is out of my car already sitting in my garage.
I was going to have a new ring and pinion gear put into the diff because it was getting a bit loud towards the end of the year… but i am seriously thinking about going a different route.
I’d recommend putting the new ring and pinion in, or just swapping into your diff case, but if you dont mine the noise it’s fine.
If you saw me at Dunnville last year you know the diff is working very well, i was spinning the 265 Potenza S03’s all over the place… but nice and predictably.
i’d take $700 and you carry it away.
the diff alone is worth WAY more than that and the bushings were like $80 - $100 too… i cant remember exactly.
serious guys only… located in Hamilton… i do not want to put this in my Kouki so i would prefer you picked it up… but semi-negotiable depending on if you want other stuff too.
