FS: CD Player, Amp, Sub, Premium Wiring Kit, 2 boxes.
Model: KD-S630
35Wx4 (140 Watts)
Detachable Control Panel
Sound Control Memory
COMPU PLAY
Power-Off Mode Eject
Preferred Setting Mode
Power Antenna Lead
Has wiring harness and all, faceplate numbers are slightly worn, AM button has a cigarette burn on it. Everything lights up on it, everything works. Other than AM, and channel buttons 1, 3 and 6 it is in excellent shape with no wear elsewhere.
Amplifier Type Dual Channel Bridgable Bridgable RMS Power at 4 Ohms 75 W x 2 RMS Power at 2 Ohms 100 W x 2 Performance Frequency Response 20 Hz - 20000 Hz Signal to Noise Ratio 100 dB THD at Rated RMS Power 0.1 % Crossover / Equalizer Bass Boost With Bass Boost Bass Boost Frequency 45 Hz Other Features Input Voltage 10.8 volt MOSFET Circuitry Yes 3 Way Ready No Dimensions Width 11.13 in. Depth 8 in. Height 2.25 in. Miscellaneous Product ID 20290127 More Information The Audiovox LXA300 has 2 Equalizer Bands. Signal to Noise Ratio: 100 Decibels.
Minor flaw on finish. Used for a month. Comes with box, instructions, and harness.
XS-L1235 / 12" Sony Xplod 800 Watt Subwoofer, set in sub box.
Description:
  • 4-layer Voice Coil - 4 layers of wire in the voice coil, increasing magnetic gauss for faster and more accurate response, and increasing power handling capability.
  • Polypropylene - A plastic based material used primarily for speaker cones due to it’s resistance against harsh environmental conditions, rigidity, and damping.
  • Santoprene surround - A speaker surround material constructed of santoprene rubber offering improved resistance to stretching.
  • Stroke Stabilizer - Adds structure to the surround to prevent it from breaking up, resulting in lower distortion.
  • 12" High-rigidity compound Polypropylene cone.
  • 800W Maximum Input Power.
  • Single 4-layer 4-ohm voice coils.
  • Durable Santoprene rubber surround.
  • Stroke Stabilizer.
  • Double damper suspension.
  • Gold-plated binding posts.
  • Optimized for small enclosures.
2 Q-Logic 12" Subwoofer boxes. You only get 1 sub, but the one box has a setup to place the amp right next to the sub for small room applications like a truck or whatnot.
300 Watt Wiring Kit, BRAND NEW IN BOX FROM DARYLS. Cost me almost 40 bucks but has everything you need to set it up
I needed this stuff gone WEEKS ago to help pay for rent, and I had to more or less bum off my gf til I get some extra money. Im looking for 150 bucks. Someone call me to take this away. 390-3083
ALSO selling the sunroof still. Only looking to get 25 bucks for a $120+ sunroof in impecable shape.
I can delivery any or all of this stuff for free so long as it is within reasonable distance
Cmon, someone make a reasonable offer, ive been trying to get rid of this for a while, someone throw me a bone.
130 for the sound stuff, 20 for the sunroof.
what about 1 Qlogic box and the sub?
would this shit fit in the back of a wrangler?? if so i might have some $ layin around
Yeah, it is all small enough to fit in the back of a wrangler for sure. The sub in the box can’t be any bigger than 15 1/2 inches height wise and same width wise. Amp is nice and small but like I said it produces good bang for being a 300 watter. I just want to get rid of it all because I would have no need for the brand new wire kit I bought if I just sold the sub/box or sub/box amp.
someone make a reasonable offer, I need em gone in the next few hours.
390-3083 if interested in anything, i can deliver.
headunit have aux. plug? for ipod?
sub, boxes, amp, wiring 100 bucks like right now.
sunroof 20 bucks again
cd player like 35?
yeah, believe it does lemme check
just a line in/out plug and antennae adapter, thats it. Then the rest of the harness.
cha’mon lee! someone buy this stuff.
15 for the sunroof
15 for the cd player
25 for the brand new install kit
40 bucks for the sub and 2 boxes
35 for the amp
Also for sale:
NEC Superscript 870 Laser Printer. Make offer
Kenmore Air Conditioner. Came out of apartment complex unit. Ice cold. Minor fin damage.
If anyone is interested in any of this stuff call me 390-3083 I need the loot for gas so I dont even care if it is an offer, ill be up all night
Air conditioner for 40 bucks, laser printer for 30
bump
pm’d
