PG7 Ecu - 50$
DOHC ZC from JDM si
price dropped on the Zc 300$ FIRM, header not included (make offers)
comes with Extra head
Si transmission
from a 90 si
100$ a piece
(no clutches included)
z6 intake, stock no rail or injectors this will bolt to any d series engine, and it flows better then your a6 intake
also allows the bigger b series and H series T/b to be bolted to it
40$
B18c Tb will fit on the z6 intake, and pretty much any B intake
35$
Stock 89 si head Complete
Plugs, cover,oilcap,head
30$
stock d16a6 crank - 20$
Z6 aem (RED) ADJUSTABLE CAM GEAR
will fit b2, a6, z6 and probably Y8
25$
was on my 89 si mini me when i bought it
                laymone
                    December 13, 2007,  7:32am
              2
              how far are you from buffalo?
compression numbers?
running?
400 for the ZC with tranny. lmk
              ill do 400 with the si tranny.
the engine has not been in a car in about 5 years, tho it still has antifreeze and oil in it.
it was pulled from a civic hatchback (obviously swapped)
i dont know the compression numbers, but im sure it gets good compression, it came from a running car that got crashed.
i would reccomend seals / gaskets like any used engine.
ive got a ton of extras for this
im in niagara fall’s Ny
willing to meet at the TOPS on military Road.
              ill even throw in the ECU with it for 400$ if your serious. i really need it gone.
              Bump, new lower prices.
i wish i could change the title to say dohc Zc ahaha
                Bull49
                    December 22, 2007, 12:27am
              6
              i think you can. go to advanced editing and do it.
                Bull49
                    December 22, 2007, 12:40am
              8
              the pleasure is all on this end
              how much power does that zc make?
 VANDIT:
120-130
130hp with a header
the benefits to a dohc Zc is, it bolts right into Stock d series motor mounts.
it bolts right up to any d series transmission.
and its low compression makes it great for boost 10 - 12psi daily driven
not only that, its low end torque makes it great because you have power when your waiting to spool.
a Dohc Zc with Si transmission, will keep up with a stock b16
and will spank a b16 with ls transmission
130hp with a header
ok, 130 hp and longer gears will not keep up with 160 hp and shorter gears. im very interested in the swap, looking for anything in trade?
i really dont need anything at the moment, im trying to liquidate stuff.
but shoot me some trade offers, or trades + cash, i could potentially be intrested in something.
you could do it here or in pm.
              bump for 280$ for the Zc with extras.
              ill sell the extra Zc head for 40$
