MK4 struts. Came off a 2004 Jetta with 40Kmi. They are in great shape, not blown rode fine when in the car. $25 ea.
AC compressor. Came off a 2004 Jetta with 40Kmi. Works fine, removed because track cars don’t need AC. $60
AC condenser. Didn’t leak, fins are fine. $50
MK4 Radiator with 2 aftermarket electric fans. Didn’t leak a drop. Fins are good, plastic fittings are fine. Includes the temp sensor that I don’t feel like taking out. $100 with fans $75 without.
SPEC stage 3 sprung clutch disk. Had 8Kmi on it. Still has plenty of life on it. 8.77MM thick pads still. Reason for selling, went to a Stage 3+ disk. $50
MK4 gauge cluster. No dead pixels or lights not working. Removed from my car, because we are going stand alone with all aftermarket gauges. $60
Radio bezel chassis. $20
HVAC dial controls with chrome plated knobs. With AC. $20
Monsoon radio. Tape and CD works fine. $60
MK4 1.8T ECU. Came from running car. Good candidate to ship out for a re-flash and still keep your original. $100
ALSO HAVE A UNITRONIC 830CC PROGRAMED ECU. Same part numbers on the ecu. PM me for details. Asking $750
MK4 Jetta GLS rear brake disks. Had 1000 miles on them before the car sat. They got rusty so I turned them. $20 ea.
MK4 fuel lines. OEM from tank forward, at the firewall entrance they have Earls -6 AN conversion fittings to allow you to run stainless braided under the hood.
4 spoke steering wheel airbags. One is for a wheel with radio controls; other is for a non-control steering wheel. $75 ea I also have pass side air bags, side curtains, impact sensors, controllers, etc, pm me if you need something like that.
