Brand new in box Mahle 10.2:1 pistons, with rings. These are the pistons Racing Dynamics used for their builds. Designed to work with “i” rods and 2.7 crank. stock bore
$500, and I’ll throw in a set of “i” rods with 60k on them for free
also have a full 2.7 block, all assembled. take the whole block for $100, or just the crank for $70. (nice so you get the crank, oil pan, and block so you can get the build ready before you have to pull your motor.
Also have catcams valve springs (cam is already sold). Springs are brand new in box
Performance valve springs: full set
“the increased duration of a performance cam with an aggressive grind forces the valve to open and close at a much faster rate. This rapid opening and closing at high RPM can cause “valve float”. Valve float is the inability for a valve spring to close the valve fast enough to avoid piston contact.”
$245
located in Buffalo, NY. will ship at buyer’s expense
