technically since it has an aftermarket differential it does not matter, gearing is absolutely the same but instead of an oem dif it has a $1,300 differential
and ctr trannys are double sycnchro’d and non ctr trannys are not…
untrue…
exacltly the same except the differential
maybe i’m confusing ep3 ctr w/ ek9
pmed
bump, updated post
How many miles on the cams? I assume they’re straight…
Also interested in the injectors and intake manifold.
gah!!! i might take that tranny from you, no clutch/flyhweel or axles tho… and maybe the mapsensor
and what comes with the “cooling” for 400$ ?
and i have a question about the car, did u paint the sideskirts? how did the paint stick to the plastic? did it come out good?
paint stuck fairly well , its all about the prepping
and the trans is for sale bc the other stuff is already sold (well the clutch and flywheel)
cooling is pretty much the same kit that tony1 sells for 700+, would take best offer, it keeps my sleaved motor nice and cool when my previous fan/radiator would get warm
mapsensor is already sold, need to update things as im in the process of moving and dont have alot of time on the internet lately
catch can sold, mounts sold, exhaust sold, wideband sold
Is that a real ITR lip? To me it looks like an Si-vtec lip which does not fit on a 98+ front end.
si-vtec doesn’t exist
learn the terminology
it’s SiR-G
and that is a usdm itr lip that he has on his car for 98+
its an oem 98-01 spec ITR front lip
The Sir-g is a JDM gsr and it never came with a lip; its front end is therefore deemed an Sir-g front end. Si-Vtec, however, is an available lip.
Si-Vtec lip (on left):
Sir-g front end:
Any other attempts and pwnage?
thanks man.
i think you look shit up on wikipedia, there is no other way you can be wrong this often
OK. You just posed pictures, do they look like anything at all that brian has on his car? :picard:
Si-vtec doesn’t exist. There is no such thing
And that second picture you posted is of a stock “lip” on 94-97
You constantly have no clue what you’re talking about. Shut the fuck up and stop literering threads
cleanest teg here. glws man!
It does exist as there are tons of trim level models that the Japan market recieved and you should take your own advice.
Si-VTEC (USDM 4 headlight front end, GSR motor)
SiR-G (“ITR” style. 1pc headlight front end, GSR Motor)
SiR = GSR (DC2 and DB8) with sunroof (b18c engine)
SiR-G = GSR (DC2 and DB8) with sunroof and full leather interior (b18c engine)
Seen this car in person!
Looks to be meticulously maintained, GL man!
For a second, it looked like an si-vtec lip and I was just curious how he got it to fit on a 98+ front end when they only fit 94-97 front end, which would be pretty fawking cool.
Oh, that’s right, I forgot you’re the end all be all of tegs. try using google to help you in your quest of this non-existant si-vtec lip and you may find a pot of gold.
u mad brah?
