Hey, I bought the Greddy E-01 boost controller from enyaw …from drift ops old s14. I have decided to sit comfy at the hp I have now…till future dates.
Anyways this was working really well in his car and I have had it sitting on the wall unit for about 5 months.
PROFEC E-01
GReddy’s new super multi-tasker is the PRofec e-01 designed as a combination boost-controller, data display / logger and e-manage programmer. The e-01 can provide superior boost response, increased boost, warning meter functions, 3 channel data-logging and access to all the programming features provided with the latest e-manage support tool. Even when used as a boost controller only, the e-01 has features to smooth out the boost curve. With both an auto and manual setting for both external and actuator style wastegates, the new PRofec can alter its new compact, high capacity solenoid valve via various RPM ranges. The large LCD screen with green electro-luminescent backlighting is easy to see. Other standard features include two preset boost levels, a timed over-take boost and compatibility with our Remote Switching System. The data display can view 3 different data channels simultaneously such as boost, RPM or any other channel inputted by the e-manage. The data can be logged up for 3 hours on an SD card while also giving warning set points and peak and hold values. There is also a non-PRofec e-01 version that is only used for e-manage programming and datalogging. (Some features require optional harness to be accessed.)
220.00, Or best offer.
The only thing this needs to work is a boost solenoid. You can either go grab a greddy one for a huge ammount of money or find a MAC solenoid that can be found for 12-20 dollars.
