Used but in excellent shape. Core has a few bent fins on one side, can be easily fixed. Lines are mint, due to plastic protective sleeves which can be removed if necessary. Everything needed for installation included, sells for over 500usd new, selling for 350cdn.
GReddy / GREX Oil Cooler Kits help prolong the life of your oil and in turn your
internal engine components. Hard driving causes higher engine temperatures.
Factory oil coolers are normally small water-cooled devices sandwiched between
the oil filter and engine block. These tax the cooling system even under normal
driving conditions. GReddy / GREX oil coolers are an excellent addition, and are
especially effective in harsh driving environments. By using a similar inner-fin
core design as our famous intercoolers, we are able to increase oil capacity,
decrease oil temperatures, and extend engine and oil life. Our systems also
offer an internal thermostat to allow for quick engine warm up. The efficient
core and durable steel-braided lines ensure good flow and a leak free
installation.
