-front rb25 crossmember $60 <-- use it on ur s13 doing a rb25det swap
S14 parts
-S14 Drivers side rear lower control arm $50
-S14 rear upper control arms $20 each
- s14 KA24DE Powersteering Pump $50
S13 parts
S13 Fastback Tailight Set with Center Garnish - $40
S13 MINT BLACK DASH $50
S13 uncut SOHC engine harness $40
SOHC Cluster $30
SOHC Manual ECU $20
Rear 4 lug hub with bearing from silvia with 110,000 km’s $60 each
Front calipers $20 each
88 silvia k’s Wing $50
Mint tranny Dust Plate $10
-3 4 lug s13 spares $10 each
-rust free s13 front crossmember $80
Lots of stock suspension pieces, rucas, lcas, spindles, hubs,
axels etc. for sale as well. Too many to list. PM For Details.
JDM s13 low milage engine mounts $60 for the pair
CA18DET ignitor chips(can be used with sr20 aswell) $40 each
Manual S13 ka Speedo Sensor $60
- turbo inlet tube $50 does not include mafs
-rust free spindles with low milage $40 each
-rust free lca’s $40 each
-OEM s13 Battery Ground $10
-Rear Brake Dust Shields $20 for the pair (jdm rust free)
-Front JDM rust free rad support cut(has been cut up to the front strut tower area) $200
*does not include headlight assemblies
DOHC MAFS $50
Coupe heads up display unit black $20
Drivers Side Pignose/Silvia S13 Turn Signal $10
Windshield wiper motor $40
