ok my friend is parting his setup which he has invested over 20k in. im parting everything out for him for some parts i need. so heres the list.
READ BEFORE POSTING
*- anything not priced make an offer
*- all prices are OBO
*- shipping will be free with the smaller parts
*- remember all the high prices on the jdm parts are due to the fact that they are brand new never even boltedup and some are very rare/take for ever to get
contact info
aim - originalsin1087
email - awoz87@gmail.com
these are the quickest/easiest/fastest ways to get a response
all parts located in buffalo, ny
all prices in USD
R32 RB26 Shortblock - selling as a whole $3600
- Bored .040 over
- Baked and magnafluxed
- Skim cut deck
- Wiseco forged and coated pistons ($750)
- Pauter rods (all within .0005 on the big end) ($1200)
- Power Enterprise black metal main and rod bearings ($700)
- Jun oil pump drive collar installed on crank (needs set screws installed) ($130)
R32 RB26 Head - selling as a whole $2300
- 5 angle valve job
- Mild port and polish
- Ferrea valve springs ($450)
- Ferrea titanium retainers ($350)
- Ferrea valve seats ($150)
- Jun extra strong valve guides ($350)
- HKS high performance valve seals ($125)
RB26 Engine parts - Aftermarket
- Exedy triple plate clutch with max pressure plate pressure $1350
- Tomei Poncam (intake and exhaust) 270 x 10.25 and Tomei solid lifters $1250
- (2) Tomei cam gears $450
- Trust clear timing cover $70
- Jun high volume oil pump (fits all rb motors vry hard to get) $950
- Jun main studs (fits all rb motors) $325
- ARP head studs $200
- High volume water pump $170
- Tomei head/intake/exhuast gasket kit (stock thickness) $300
- Power Enterprise super strong timing belt $125
- Custom made driveshaft for rb20 trans $175
- McKinney RB motor mounts $350
- McKinney Motorsports RB25 s13 driveshaft $400
RB26 parts - Stock
- t25/t3 hybrid (1 left) $200
- (6) 450cc injectors $150
- Turbo manifold
- Individual throttle bodies from intake mani
- Cams $200
- Pistons and Rods
- Valve springs and retainers
- Timing Covers
- Water pump
- Oil pump
- Valve components (ex. valves)
- ECU $200
- RB25 oil pan made to fit RB26 $250
- Timing belt tensioner assembly (brand new)
- RB20DET transmission
- RB starter $175
Other aftermarket parts
- (6) RC Eng. 1000cc top feed injectors (brand new) $550
- Greddy warning guages 60mm - Oil temp, Water temp, Fuel Pressure $150/each
- HKS Type 1 turbo timer $100
- PWR FMIC 24x11x3 w/tabs to fit s13 $350
- AEM fuel pressure regulator $120
- Garret GT3040R w/vband, polished, coated (needs rebuild) $450
RB equipped 240sx plumbing* selling as whole $500
- wastegate dump tube
- aluminum mandrel bent fmic tubing w/hks bov flange
- T3 tubular turbo manifold
- 3" mandrel bent exhuast w/electronic cutout
- (was installed on RHD car so the downpipe may need to be modified to fit LHD car)
some pics, more can be had on request
**block before machine work
