Hia people
I’m selling my KORG X3. It’s a professional level synth but is easy to use by a novice. The keyboard does have few usage “scuffs” that were there when I bought it, but everything is in perfect working condition. It’s a solid keyboard.
The keyboard comes with: power cable, carrying case and operating manual.
X3 features:
Synthesis-type: AI2 (Advanced Integrated Synthesis). mawa’s X5 w/u gives a clear explanation of how this works.
Program architecture: Programs (patches) can consist of 1 or 2 PCM elements.
Sample-resolution: 44.1 kHz
Keyboard: 61 keys, velocity sensitive, aftertouch, light action.
Programs:336 (200 internal RAM, 136 internal ROM)
Combinations:200, internal RAM
Polyphony: 32 PCM generators. In program mode: 32 notes for single oscillator program; 16 notes for dual oscillator program.
Multitimbral: 16 parts
LFO: One pitch LFO, one amplitude LFO and one filter LFO for each oscillator.
Envelopes: Attack time, attack level, decay time, break point, slope time, sustain level, release time for amplitude and filter on both PCM oscillators. Start level, attack time, attack level, decay time, release level for pitch (shared by the 2 oscillators with adjustable bias)
Effects: 2 stereo programmable effects processors, 47 types of effects, real-time controllable. 1 type of serial and 3 types of parallel routings.
Audio-outputs: a stereo pair (X2 had 2 stereo pairs), Left channel doubles as Mono-out, headphones.
External storage: RAM or ROM voice cards, PCM cards, 3.5" DD MS-DOS-compatible disk
Card-slots: 1 Korg Prog/Seq data card slot, 1 Korg PCM card
MIDI connections: In, Out, Thru
Display: Backlit LCD, 2x16 text area, numeric 3-digit display, status indicators.
Inputs: keyboard, modulation wheel, pitch wheel, assignable pedal, MIDI In/Thru, data slider (this slider, although fiddly and flimsy, can be used to enter all kinds of live or programmed data - modulation, resonance, effects level, etc.)
Weight: 10 kg
Dimensions: 1055 x 338.3 x 96 mm (W x D x H)
The sequencer:
Tracks: 16
Songs: 10 (which can be set-up to play in sequence)
Polyphony: 32
Capacity: 32 000 events.
Modes: real-time (overwrite or overdub), step, punch-in (manual or automatic), loop. All of these recording modes can be used on several tracks simultaneously.
Resolution: 1/48th or 1/96th of a quarter note. Not all time signatures are available at 1/96th resolution.
Patterns: 99. (These can either be inserted into songs, to save memory, or just played by themselves, e.g. for chord progressions)
Here is more information on it: http://everything2.com/title/Korg+X3
-One great thing about this synth is that you can create and tweak instruments on the computer and upload them
to the synth so you can use it live or for making songs, etc.
-I have loaded 2 sets of quality instruments I found on a korg forum already.
-I will include a keyboard case and power cable.
All you need is headphones and some table to put it on to get going.
PRICE: $320 (pickup in Waterloo)
Thanks for viewing my ad. If interested, please PM.
