Lincoln Electric wire welder
Includes most of a 10# spool of 0.035 innersheild wire
$250 OBO
I used it for exhaust & charge pipe work, did great.
First link i found with description, here
“Lincoln Electric 115 WELD-PAKT Wire-Feed Welder — 100 Amp, Model# K587-1”“Welds mild steel from 20 to 12 gauge. For gasless flux-cored .035in. wire welding. Produces MIG (gas) welds with our #164351 Conversion Kit, call to order separately. 115 Volt, 60 Hz, 20 Amps input. Rated DC output of 88 Amps @ 18 Volts, 20% duty cycle. Max 32 open circuit Volts. Wire speed 50in. to 300in. per minute. Uses 4in. O.D. x .62in. I.D. x 1.7in.W spools. You get welder, gun and cable, 1-lb. spool of .035in. self-shielded wire, work clamp and cable, welding shield, spare tip and FREE video. 12in.H x 9 3/4in.W x 16 1/2in.D (less handle). 3-year limited warranty. CSA certified and UL listed. U.S.A.”
Owners manual .pdf
Similar to this, newer model
