I have a bunch of misc turbo parts I would like to move out to make room for more
Everything OBO, let me know if you would like better pics of anything. Everything is located in Greensburg PA, will ship out smaller items if you prefer.
Aftermarket (Turbonetics) dual port waste actuator with adjustable arm plus laser cut mounting bracket for T4 compressor. Never used, was bolted up to mock up and I’m going a different direction. $80.00
http://rides.webshots.com/photo/2918398540066453426QYnFvI
http://rides.webshots.com/photo/2142544730066453426Dlniob
http://rides.webshots.com/photo/2509350360066453426YCVZig
http://rides.webshots.com/photo/2605814280066453426syAICG
Aftermarket (Precision) single port waste gate actuator with adjustable arm. This one has a welded bracket set up for a T3 compressor housing. $50.00
http://rides.webshots.com/photo/2263806400066453426vVFVGU
http://rides.webshots.com/photo/2095303220066453426irumyD
http://rides.webshots.com/photo/2388683680066453426zddLWd
Stock (Garrett) wastegate actuator for Ford / Garrett T3 turbo. This one still has a good heat shield (usually rotted off). $40.00
http://rides.webshots.com/photo/2115365190066453426WngsHo
http://rides.webshots.com/photo/2674573050066453426FDmdiV
http://rides.webshots.com/photo/2441210980066453426nIBQKQ
Stock Ford T3 outlet elbow with internal wastegate puck (swing arm). This one has the studs removed for use of through bolts. I change mine to this way so I can drop the exhaust without getting under the car, plus it seals better this way (downpipe not included ) I know some guys use the Ford stuff outlets for custom applications. $30.00
http://rides.webshots.com/photo/2687512880066453426dapKGe
3" downpipe for 2.3 turbo fox chasis car using stock outlet elbow. (Turbo elbow not included, but would package these items). Great start for a custom set-up, has outlet flange and two bends. $65.00
http://rides.webshots.com/photo/2889330550066453426okpVfa
Weld Draglites, 15 x 7, 5.5 BS. These have dual 5 lug pattern both Ford 5 x 5.5 and GM 5 x 5.75. Wheels only, the tires are gone. $150.00
http://good-times.webshots.com/photo/2263350060066453426hkwEdw
http://good-times.webshots.com/photo/2821037900066453426SaSFhG
I also have a pile of core T3 turbos. Most have something significant wrong with them
lots of broken shafts, muched compressor wheels, etc, but bits and pieces as needed. Let me know what you might need and maybe we can come up with something
Make offers on what you need in the picture, at a minimum, they can go as cores (most rebuilders are charging bigger amounts for cores these days).
http://good-times.webshots.com/photo/2681368680066453426oisKHm
I also have several 87/88 Thunderbird Turbo Coupe intercoolers if someone wants to play around with them for a custom application $20.00 each.
Everything OBO, make offers, plus shipping. Would consider trades on turbo related parts, looking for an external 46mm wategate (flange type).
Bob Myers
