Update. Im dropping my prices. I need to get rid of this stuff asap. shoot me some offers
Iv got a red 87 AW11 w/ T-tops that Im parting out. Everything is is available except the engine, seats, all four break caliper brackets and metal part of the rear bumper. The skin of the rear bumper IS available however. There is no A/C.
The car is basically intact except the passenger side suspension. The car slid sideways into a curb pretty hard and the front and rear passenger side wheels are noticeably bent in and under. The front more-so than the rear. Id say they’re about 3-4 degrees off. However Id imagine the struts and springs are still ok. You get the point. There is also a bit of rot around the panels and what not.
Payment
my paypal address is Deadbunny29a, AT, Yahoo, D0T, com.
Sold parts complete list!!
both fenders
sun visors
C Pillars
front lip w/ brackets
seat blets black
side vent
Headlight switch
Antenna & elec
Frunk latch
left foot rest
wiper switch
inside of the glovebox
shift knob
shift boot
cigerete lighter
rear int vents
trunk lock
fuse box trim cover
passenger int rear side trim
drivers side int a pillar trim
dome light
rear top int trim
rubber strut caps
triangle mirror trim
Engine lid prop
driver side door panel
dash skin
spark coil
Tvis solinoid
engine pecker hooks
Intake manifold bolts
Exhaust manifold bolts
Exhaust manifold support bracket
cable that goes from the throttle body to the “hub” rotor
Coil pack bracket
All clutch lines
4 tranny bolts
engine wiring harness
cat
tail lights
steering rack
rear sub frame drivers side
alternator
Cover trim where the T-Tops push/lock into the roof frame. Both.
Headlight front eyelids
Shifter cables
E-brake cable
rear int quarters w/ speaker grills
trunk lid w/ wing
distributor
throttle cable
engine bay wind deflectors
Instrument cluster
Throttle linkage
spark plug valley cover bolts
driver & passenger side door hinges
HVAC Control unit
housings for all 4 struts
Steering wheel
tranny side mount
all tranny selector arms
tranny selector shaft
tranny shaft cap
tranny shaft boot
tranny heater hose mounts
tranny radiator hose mount
driver side mirror
front bumper
Shipping -------------------------------
Shipping is pretty standard and Im not gonna jack up shipping prices. This isn’t E-bay. I’ll pack super fragile parts vary well and I’ll use UPS, USPS or FEDEX. whichever you prefer. I’ll calculate shipping for you but if you know the size and weight and want to calculate your own shipping I wont complain. My zip is 14615
Pictures
This is some of the parts in a locker in my basement.
More photos can be found here HERE
