I no longer have the car so all the extra stuff i have needs to go!All prices are obo and i am willing to ship if buyer covers shipping charges. All items are located in Lethbridge AB. I accept payal, email interac transfer, and cash(local pickup only).I will have pictures of all the items up tommorow! Additional photos available upon request.
HKS Super AFR. Brand new! $150 SOLD more info here: http://www.hksusa.com/products/more.asp?id=811
http://i69.photobucket.com/albums/i61/mini_me1209/DSC00083.jpg
Farina Racers Carbon Fiber glovebox guage insert. This is the real deal no fake carbon fiber here!! 70$ SOLD
JECS 80mm MAF sensor w/ plug & 4 inches of wire - part number 22680 16V00 A36-000 N60. This part number matches up with Nissan models (C33, Y31, A31, Y32 etc) as well as R31 RB20. Although i believe you can make it work with an r32 rb20det. It is in excellent shape. 60$ SOLD
BRAND NEW authentic Nismo front brake pads for r32 gts skyline or any other r32 with small breaks. WILL NOT FIT type m’s. part number 41060-RN584 . From what i know these are S-tune (non-type m) pads which retail for $199. OFFERS
NGK rb20det O2 Sensor- used but in great shape. $30
OEM Pitwork rb20det timing belt-brand new still in the wrap. $70
New, never used intercooler. Universal no name. $150 SOLD
New, never used Hayden thermostatic fan controller. Comes with instruction and a bunch of terminals/connectors. Missing the lil plastic thing you use to hold temp sensor in radiator fins. You could rig sumthing up real cheap! $40
Adjustable turn-on from 160° to 210°.
Can be turned on automatically when AC is engaged.
Can be wired to augment factory switch, not replace it.
Can be manually turned on with a dash-mounted switch.
Lincoln Mark Vlll 2 speed electric fan and 8 zip tie like mounts. This is a serious fan for serious cooling needs! NOTE: The Lincoln Mark VIII fan will draw continuous currents of 33A @12.0V & 42A @14.4V, and has a starting current in excess of 100A I cannot remember what rb alt. output is but i do believe it’s less than 100amps. you may need to upgrade alt or at least a real good battery. I would recommend this fan for a track car. It’s an 18" fan blade. Estimates of CFM are between 4300-5500. Draws 42amps on HIGH speed–it is a 2-speed fan. 1100 rpm in slow, 1850 rpm in fast. This fan as been trimmed down to allow fitment. Measures 21 5/8" wide, 18 1/2" tall, roughly 5" thick, if anything a lil less.
$100
Rb20 coil packs- 35$ each or all four for 130$. No cracks, plug clips are intact not broken. lots of meat left on the carbon tips. Last time i tested them they were all within spec. I will retest them in the comming days and post up results! SOLD
You can contact me easily through necc or email me at mini_me1209@hotmail.com. Items will ship within a day or two of purchase. If you would like a shipping qoute pm me with your postal code
