Moving out of my shop, I think these are the last parts I have sitting there that I don’t need.
R34 RB25DET Neo short block with low compression on 5 and 6. IIRC it was about 60-90psi. There are very light scratches on the cylinder walls in one place on each cylinder, you can barely feel them with your finger nail. Complete assembled bottom end with crank, rods, pistons, 4wd oil pan with the diff cut off, water pump. $50 pick up only.
S13 SR20DET in parts. I never had this motor assembled but as far as I can tell everything is in good condition. The head is assembled but off the block. Bare block, rotating assembly in parts, misc boxes of extra parts, doubles of a lot of stuff, some new parts (timing components and misc gaskets IIRC). No valve cover, oil pan, injectors, turbo, wiring harness or ECU. It’s just the long block with manifolds in pieces. $150 pick up only.
Located in Cambridge, Ontario.
PM me.
