RC Fuel Injectors SL9-310 for Honda/Acura. Set of 4 310cc High resistance (Saturated) flow matched fuel injectors. They were in my car for two season about 6-7k miles on them, in great shape no leaks $150
Flow Rate - CC’s: 310CC @ 43.5 PSI
Flow Rate - LB’s: 30LBS/ HR @ 43.5 PSI
Resistance: 12.5 ohms @ 68 F
Voltage: 8-15 Volts, nominal 13.5 Volts
Amperage: 1.0 Amps
Pressure: Min 30PSIG/ Max 100PSIG
Part Number: SL9-0310
Are these from when you were NA?
I wondered. Didnt think 310 was nearly big enough for what you were running. Will these clip straight to the Honda harness?
hahaha 310 is wayyyyyyy to small, i was running 1000. they clip into obd 0 and obd 1 plugs,if its a obd2 car you have to get the injector clips which are $15 for a set of 4 and these dont need a resistor box
so i was juSTINKIN here and theres no price
OO Peter
thanks i forgot to put a price in. Edit
