I don’t want to bother taking the time to install them so my loss is your gain. I can hook you up with installation guides too if necessary. Install usually takes up to 8 hours with no special tools, a bushing press is required though.
All the info is in the link I posted, but here it is anyway.
Energy Suspension HYPER-FLEX System Complete Master Bushing Set for the 1989 - 1994 240SX.
Set includes:
Front Strut Rod Bushings
Front Control Arm Bushings
Rack & Pinion Bushings
24mm and 25mm Front Sway Bar Bushings
Endlink Bushings
Rear Subframe Inserts Bushings
Rear Suspension Arm Bushings
Rear Sway Bar Endlink Bushings
