This engine set comes with a brand new wiring harness that i got from a nissan dealership in japan, ecu, MAF and ignitor…
compression #'s are 170 ish all across…
$ 2900 OBO…
pics of exact motor below.
call me or pm me anytime so make an appointment to come see it.
varun.
compresion #'s is a measurment in psi, basically the higher the compression, the better the engine, i think the compression from the factory compression is 180, so 170 would indicate that this motor is in excellent shape.
It comes with all you need to install including the tranny. Varun makes sure he sells motors that can be swapped with ease.
A motor set is COMPLETE motor, tranny, turbo, wire harness and ecu. It’s almost like having a front clip (the front part of the car cut at the A pilar or firewall) but without the frame work and so on. These come with rad’s, hoses, side mount intercooler’s and all the nuts, bolts and clamps. When your done removing all that, the rest of the engine bay becomes a useless 1000lbs paper weight. :lol:
Just want to clarify for the good people since your post is a tiny bit ambiguous.
What Bruce is saying is that -clips- come with the rad, intercooler, nuts/bolts/clamps/etc. Motorsets do not. Motorsets include, as Bruce already mentioned, the motor with all manifolds and accessories, transmission, ecu, wiring harness and, when you buy from Varun, an ignitor chip and brand new harness.
Unfortunately that will not be happening . I wish I could but I don’t see the swap happening before the meet . And since in will not happen before the meet I will probably hold of for now. Im going to be spending the majority of my summer in the Greek islands so I might hold off and do the swap when I get back in September. Im not sure yet I guess it all comes down to time and money.
Unfortunately that will not be happening . I wish I could but I don’t see the swap happening before the meet . And since in will not happen before the meet I will probably hold of for now. Im going to be spending the majority of my summer in the Greek islands so I might hold off and do the swap when I get back in September. Im not sure yet I guess it all comes down to time and money.[/quote]
