I have the following items for sale.
Stock S13 suspension with KYB GR2 struts (1 winter on them) Asking $100
17" Silver BSA 296 (5x100 and 5x114.3 bolt pattern) rims with Hankook w300 Ice Bear winter tires (205/50/R17), good tread but it is really uneven due to bad alignment when used (1 winter). They clear 26mm Z32 Calipers by about 2-3mm Asking $400
17" Light Gunmetal Grey Gramlight 57S they are 17x8.5 with +30 offset all around. It is not Uber flush but enough to require a slight rolling if you run a slammed configuration with stock camber settings. They have Kumho SPTs mounted with the size 225/45/R17 all around. Two of the tires have good tread but the two that I ran in the back are pretty much at the tread wear marks. Rims are in great shape, one of them has very slight rash from a raised manhole on an under construction street. Below are some pics of how they looked on my S13 with Megan Street coilovers and no alignment fronts at 0 degrees camber setting on the coilovers and rears with whatever camber they cause. Asking $1500
