I’ve been swanped with PM’s, and most ask the same questions. So I will answer some of them here instead of replying to 100 PMs.
DROP:
FRONT - 1.4"
REAR - 1.2"
SPRING RATE F/R- 3.2KG/2.9KG- 179LBS/162LBS
TEIN S.TECH Spring is an excellent step towards suspension tuning. They offer approximately a 1.5 inch drop for a more aggressive appearance. Comes with a 1 year limited warranty. Spring length is guaranteed not to sag more than 5mm and to be clear of any manufacture defects (see limited warranty for more details).
One year limited warranty.
High-grade material adapted to improve guaranteed satisfaction.
Rubber spring protector sheet to prevent noise (most applications).
I do not recommend using stock shocks.
I will not part them. All 4 springs are sold as a SET. If you also want the shocks +$, if you want the stock springs, then +$ angain.
SPRINGS ARE STILL ON THE CAR. THEY WILL COME OFF IN EARLY JULY.
thanks for all the interest, and i will post here again when they are off the car. so stay tuned if you are truly interested.
So July is just around the corner, still taking them off? what are the chances you would drop them of in Burlington-Oakville? Price seems fair, but there is always room for improvement?
that could work, its pretty hard for me to get out from work, but i am interested. If that is something that you would do? What would you want, total for the springs and the gas?
