in what shape is the vlsd?
i will measure the ebrake line this weekend…overall the shape is excellent…no problem…run fine…
Hows the LSD, interested in it
the reason i have a spare one because i thought this lsd side bearing are worn out…but after i have replace it, the noise are still there…end up it was the the wheel bearing and the tires are no good…therefore this unit is still good…i think this lsd has only 140,000kms with syn oil in there…but the only problem is the input shaft flange bolt holes have some burned marks…(because the bolts are seize and i have to use a torch to cut the bolts)…
z32 ebrake cables are 44inch long!
any chance you have a power steering pump?
---------- Post added at 03:42 PM ---------- Previous post was at 03:39 PM ----------
do you have a power steering pump?
the only remaining parts are listed in page one
