FS: spare sr20det block and head..
This block and head is attached in one piece and starts up no problem…motor was in the car and was runnying shaky, so we compression tested and found that the 4th cylinder was not as good as it should be…its most likely the valve seal because if it was the rings they usually all go at the same time…cylidner, 1,2, and 3 all have 150psi cold all across…only # 4 is low…this price includes the valve cover and complete internals also…intake manifold will also be included…no exhaust manifold or turbo…
$ 500 OBO…
