i just pulled a set of digital designs 5.2" cx’s and a pair of the ddt 28mm tweeters . these are about 6 month old or less. id like to get $60 a pair or im open to trades, i could use a better then stock coil, some gauges(volts, a/f , fuel pressure) or just some cash…
if ya need any info on the stuff go to ddaudio.com
next i have an american bass sq780 rated at, RMS @ 2 Ohm, Stereo: 160W x 4 Ch.
RMS @ 4 Ohm, Stereo: 100W x 4 Ch.
RMS @ 2 Ohm, Mono: 300W x 2 Ch.
RMS @ 4 Ohm, Mono: 260W x 2 Ch.
ill take 200 b/o on this the board was cracked in shipping but all is well took me longer to wait for the soldering station to heat up than fix… remote trace was broke on the board. outside is a 9 outta 10 and you almost cant tell i was inside it…lol… also that pic is how i got it but its the only one i took…just needed it for the sender…
