SR engines are old. Its time for new gaskets. I have a bunch of gaskets and random parts for sale. I bought a engine gasket kit and only ended up using some of the parts. These parts are ordered for a S14 engine, but most if not all can be used for s13 SR as well.
Please pm me if you need more information.
Shipping is available at buyer’s expense.
All prices are firm.
SOLD 7 layer exhaust manifold gasket - best gasket you can get
$30 Single layer exhaust manifold gasket - good enough if you granny drive your SR
$100 Nismo clutch pivot ball - highly recommended if your running any aftermarket upgraded clutch
$30 s14/s15 intake plenum gasket
$35 s14/s15 intake manifold gasket
$40 s14 oem head gasket
$60 exhaust valve stem seals - must have for cylinder head rebuilds
$60 intake valve stem seals
SOLD turbo gasket package- comes with turbo 4 bolt inlet, 5 bolt outlet, inlet tube, outlet tube, oil drain, copper washers for coolant and oil line
$80 s14 radio trim - you will never find a used one in good condition, mind as well by new
Maintenance parts may seem expensive when you add it up, but put it this way, new gaskets will last you 5-10 yrs easily. Its ten times better to work on a oil leak free engine/car.
