Stock Manifold.
Will NEVER Crack. Will most likely keep it but I’ll post it for $40
Turbo elbow / o2 housing
No cracks with a divided wastegate outlet.
Also has a wastegate divider (thing in the middle).
All the studs broke and when I went to replace them, the drill bit broke.
It either needs to be drilled out or needs a new flange.
I have no time or patience for either so I bought a new one.
Looking for $50
Also have a Z32 4 inch MAF adapter w/airfilter. It has NEVER been used. just sitting around and test fitted.
This comes with the expensive and hard to find reducer from z32 to stock intake pipe.
Looking for $70 for the MAF air filter setup.
Also, a Nice working Z32 Maf for $120 bucks. Thing is super clean and looks great.
This is a Freebie.
S14 SR block on the right is free.
SR on the Left will be over $1000
I was going to build it but I got lazy and just bought other engines.
Pick up ONLY in Oshawa on a weekend.
Block, mains, previously bored to .020 over and will need to go further before using.
I melted a piston in this one 2 years ago.
NO CRANK.
Remember, Bare and FREE.
If not picked up by the weekend, i will end up tossing it. I just figured someone may want it.
Just an FYI… That SS manifold most likely cracked because it was wrapped… Wrapping SS is never a good idea. SS and heat do NOT play well together. And wrapping it only traps that heat in.
I’ve had a few guys inquire about the Mani, o2 and z32 Maf Adapter.
Make offer on the Exhaust stuff.
I also have a box of old SR rods and random pistons in case anyone wants them. Free for pickup.
The Z32 Maf Adapter is a a complete set. Includes the adapter, filter and coupler reducer/ joiner pipe from the z32 maf to the stock SR intake.
Would really like to keep that together.
If you have 2 stock pistons, send them my way.
I melted 2 on a stock block, and a buddy guesses I’ll be fine with a quick hone + stock pistons for a spare.
Just sayin…lol
