OEM MOTOR PARTS:
-sr20 transmission $200
-sr20 mystery transmission $100
-sr20 starter motor $80
-sr20 x 4 coil packs $80
-sr20 alternator $80
-sr20 OEM flywheel recently resurfaced $80
-sr20 x 2 engine mounts $40
-s14 sr20 rad $60
-s13 sr20 rad shroud $40
-sr20 OEM rad hoses $40
-sr20 blacktop valve cover $50
-sr20 x 4 OEM injectors $60
AFTERMARKET MOTOR PARTS:
-act 6 puck up sprung heavy duty pplate can hold 450hp less than 3,000km’s on it purchased brand new amazing shape grips like crazy $350
-Aftermarket light weight flywheel sr20 $200
-Garrett GT2871R .86 exhaust housing turbocharger used with less than 3,000km’s on it, the turbo is welded onto a stock exhaust manifold for reliability it will never blow an exhaust gasket again! Amazing for the track. Comes with SS braided taka lines with s14 coolant elbow, custom aluminum intake pipe with cone air filter, GReddy 02 extension elbow and t28 oil drain $1350
(the turbo alone is worth $1500 + GReddy 02 extension is worth $200 + TAKA lines are worth $200 + intake pipe + oil return is worth $60)
-APEXi Power FC D-Jetro $1450 map sensor version
(has SG motorsports tune on it for gt2871r made 310wheel hp)
(purchased brand new)
-TOMEI injectors in sr20 fuel rail with brand new injector seals(purchased brand new installed had motor tuned and did 1 drift day thats it!)$500
-S13 FREDDY Chrome Knockoff intake manifold brand new mounted on motor but never used $180
- 3” Stainless Steel Aftermarket downpipe with cat delete (this is a single downpipe that removes to the cat as well so you don’t need a testpipe, also bonus you have less gaskets ) almost brand new $150
Please PM me for pickup instructions
thanks for viewing
Avery
whats the condition of the sr tranny.
wouldn’t happen to have a fuel filter with all that would you?
How much for just the stock sr20 fuel rail?
act 6 puck clutch
both SOLD
sold a bunch of parts here is the Updated List
OEM MOTOR PARTS:
-APEXi Power FC D-Jetro $1450 map sensor version (for s13 sr20det)
interested in rad shroud
are those stock engine mounts?
hey bro you have a s13 sr20 maf sensor by any chance
stock engine mounts yes
no mafs right now
UPDATED LIST
OEM MOTOR PARTS:
car you do any better or the mystery transmission. I am looking for a blown/cheap sr tranny because i need the front cover that the clutch slave slides on and the clutch pivot ball mounts to. The peice that the throwout bearing slides on broke off on mine.
Let me know if you still have it please.
UPDATED LIST
OEM MOTOR PARTS:
-sr20 transmission $240
-sr20 mystery transmission $120
-sr20 s13 blacktop valve cover $50
