FS: Tein HA Coilovers, Mines ECU, SR20 T25, Injectors and MAFS
Hey guys, I am planning to revamp my setup this summer. So I got some really good stuff up for sale. All parts are in mint shape, and I can deliver for free within the GTA. PM me if interested or call 647-407-5551. Thanks, Tony.
JDM Tein HA Coilovers - has less than 20k on them. Spring rates are 8k/front and 6k/back. 16 way damper adjustable. There are no leaks and the shocks are in great condition. I used anti-seize on the colors every time when adjusting height. Very good setup for street and light track use. – Asking $750
Mines Tuned ECU - Code for ecu is E5. Will work on S13 Redtop SR20 motors and Blacktop motors that are 1995-96 models. Will not work for Type X model. This is a boost up ECU what works with the stock T25 turbo, injectors and maf. It has a leaner fuel map and you can see substantial gains when boosting 12-14 psi. – Asking $250
SR20 T25 Turbo – This is a low mileage turbo that is coming of my S13 Blacktop. Mint condition with little to no shaft play. No leaks and doesn’t blow smoke. I am just opting for a bigger setup. – Asking $250
SR20 S13 Injectors– All 4 factory 370cc injectors. Perfect working condition. – Asking $60
SR20 S13 Mass Air Flow Sensor– Factory MAF from my S13 Blacktop. Perfect working condition. – Asking $60
pmd
ah… i wanted to lowball you for your car this year.
Hahaha…well I might be calling you later this year from some parts, so you still benefit.
Everything is sold…Thanks for the interest.
yo ,thanks .Ill’ probably install next week.might have to call Varun for a gasket or two
