370CC Stock SR injectors, All 4 in good working order, profesionaly cleaned about 2 years ago
$200
A True SR maf, SOHC ones will work on an SR but resolution is slightly different on the SR one
$50
Megan Turbo Extention, Used for a year or two. Will throw in an OEM nissan O2 sensor with no connector
$100
Brand new Internal Wategate fot GT series turbo’s. Adjustable arm, i believe you can get between .7 and 1 bar on this with no boost controller.
$100
SR CAS, Broken clip and missing cover, but works fine. Perfect as a spare or if you are in desperate need of one
$50
Stripped SR intake mani, Good to modify. I have heard you can bolt up the bottom section to the upper section on your KA and gain alot of top end. Dunno how true this is but bolt pattern is the same
$50
And for the SR motor is have
Stock oil pump 75
S13 upper water outlet 50
All heat shields 5 for all
Misc gaskets, sensors and plugs
Basicly if your missing somthing small i have it, or if your missing any harware i bet you i have it
