this is brand new, still in the box. made for the KA24DE. comes with a front main seal which should be changed with the pulley($25 value). $200 firm
ttt
does anyone know how much power these will produce?
I know on 5.0L mustangs underdrives are worth 10hp to the wheels…
only cause i work at the mustang shop
this pulley creates about 8 hp. install an electric fan at the same time and you should get a little more…
bump
i have 1 but i bought a generic one for 65$ +shipping i think …works well super light vs factory.On mine for alternator i had to use a belt size smaller than oem too. Motor spins up faster i dunno about hp gains, but i also run 300zx clutch kit and bigger flywheel so that takes up some extra weight and gives quite a clamp.
bump…open to offers.
ttt
bump
bump. $220 with the front crank seal
200 $ with the crank seal.
ttt
