I have a BRAND NEW tranny from a 95 300ZX non-turbo (So the reverse switch was a direct hook up. The TT required wiring work) and a kit that bolts it right up to any S13 SR20DET motor. I sent it away to get the bellhousing machined with an adapter plate for the SR20, a 1 piece lightened molychrome driveshaft, brand new short shifter, new bellhousing bolts. I’ll get you pics. But anyways, this is a much cheaper route then those HKS transmissions that run close to $10,000 canadian. This transmission upgrade will out last the car and take any abuse you send to it. Looking for $3200. This tranny has 0 miles on it, BRAND NEW. The tranny was $2500 and the kit was $1200, have the bills to prove anything that needs to be proved. I’m taking a hit just to sell this as I need the cash for a truck.
Theres no kit like this, it’s a direct bolt up. I went through the trouble so you won’t have to! $3000 walks away with it. I throw in what I can like my stock SR20 starter (If you want)
is this the 3rd thread!
http://www.n-e-c-c.com/forum/viewtopic.php?t=10163
http://www.n-e-c-c.com/forum/viewtopic.php?p=86629&highlight=#86629
Either contribute properly, or stay out. I already explained myself…
$3000 is obo so make a decent, reasonable offer! End any tranny troubles for the rest of the life of the car! It’s a brand new tranny with a brand new driveshaft, shifter, everything!
BUMP
if only i had 3 gs.
Yep, it will end all tranny problems for the life of the car…
$2800 new price FIRM!
Bump
Pics! These are great quality parts. I WON’T part out either.
-1 piece driveshaft with new u-joints and their greasable and everything. It is much better then your stock 2 piece, you’ll get more power to the ground, less drivetrain to go through!
-1 brand new B&M shifter
-1 machined adapter plate to bolt the Z32 tranny to the SR20DET.
-Bellhousing has been machined
-All new bolts supplied
-Block off plate for the old shifter hole
-Extension piece to mount the shifter
-Brand new transmission mount carrier
-INSTRUCTIONS INCLUDED!
You WON’T find this kit anywhere unless you went through the trouble I did! I gaurantee you won’t find another one and you won’t be disappointed with this kit either! Need to sell, buying a diesel truck for work!
It bolts right up. Your stock SR20 clutch will work with this too. This is all just bolt on and drive away.
Buy this and I’ll throw in front and rear strut bars and a c-pillar bar for FREE! Brand new megan racing, never used, never installed. I need this stuff GONE! Spend the money now, NEVER have to touch the tranny again. It’s proven to handle 500+ coming off the SR20 motor
Have 1 interest but it’s not for sure yet, come on guys! First come, first serve.
A couple people have seen this kit and they could probably tell you that it’s not poorly put together…
+1 to this. I seen it today while i grabbed some suspension peices. Looks great, too bad im poor and couldnt afford it. Someone should snatch this up, great upgrade, very nicely put together!!!
i wish i had the money for this, just picked up a clutch and flywheel. would be nice to do it all at once
Bump
And bump
I’ll take reasonable offers…
$2600 New price FIRM. Thats hardly the price of the brand new transmission alone! This includes an entire brand new tranny, sensors, everything! and the adapter kit! Get in on this!!!
