Jesse
803 389 three zero four seven call or text
Located in Binghamton NY. Was planning on a big build, but have decided to go a different route.
OBD1 GSR Harness all sensors present USDM. $150
P72 GSR Oil Pan $50
Unorthodox Racing pulley B series no AC/ PS $50
GSR Head bolts $20
Skunk2 Pro GSR Intake manifold NEW NEVER USED (has idle valve attached) $200
Skunk2 Pro throttle body (70mm?) NEW NEVER USED $175
B series valve cover with Honda logo shaved off $50
Skunk2 Stage 1 Tuner series camshafts (you can call Skunk2 to verify) NEW 0 miles- only turned over to time engine! $275
Skunk2 Cam gears B Series GSR New never used! $175
OBD1 GSR Distributor (fits All B series DOHC) $100
Fully Built GSR Bottom end for boost $1000
a. OBD1 Block
b. Fully degreased, media blasted, bored 81.25
c. Eagle rods
d. Mahle ACR181199F01 pistons (approximately 10.5:1 with GSR head)
i. Better throttle response / spool than 9:1, still good for well into the 600whp range!
Fully build GSR Cylinder head Everything is NEW 0 miles $1000
a. OBD1 head with VTEC Solenoid
b. Fully degreased, media blasted, race valve job
c. Skunk2 pro race valves
d. Skunk2 dual valve springs
e. Skunk2 Titanium retainers
