Decided it was time to clean out the garage a bit. Listed up a few misc parts I have lying around.
18" drift spares. $50
Tires are Pirelli P-Zero Rosso’s. 255/40R18
You can tell how much tread is left on them from the pictures. You could get away with street driving them for a bit if you needed to but these are mainly listed up as drift spares.
Ka24e Hot Shot header $80
Little rusty around the welds but in great shape. When the previous owner had it installed his shop cut the flange off and welded it straight to his cat. No flange on the end!
Ka24e Injen Short Ram Intake $80
Follows the same path as the stock intake but has increased flow capabilities. I can’t find the actual pipe right now but as soon as I do I’ll get pictures. Comes with Injen cone filter and Maf/Maf adapter.
Ka24e #10 5 speed ECU $45
Great working shape, not corroded and all the pins are there.
SR crank with a spun #4 rod bearing - Best offer
I was going to get this machined down and use it with oversize bearings but instead just got a new crank. Make me an offer on it.
