Brand new Garmin etrex vista H
https://buy.garmin.com/shop/shop.do?cID=145&pID=30122
Retails for 200 new.Im asking 160 new
Ideal for serious hikers and climbers, the rugged eTrex Vista H features a high-sensitivity receiver, detailed basemap, barometric altimeter, electronic compass and 24 megabytes (MB) of internal memory for extra data storage. Enjoy Clear Reception
With its high-sensitivity, WAAS-enabled GPS receiver, eTrex Vista H locates your position quickly and precisely and maintains its GPS location even in heavy cover and deep canyons. The advantage is clear — whether you’re in deep woods or just near tall buildings and trees, you can count on Vista H to help you find your way when you need it the most.
Get Your Bearings
The Vista H has a built-in electronic compass that provides bearing information even while you’re standing still, and its barometric altimeter tracks changes in pressure to pinpoint your precise altitude. You can even use the altimeter to plot barometric pressure over time, which can help you keep an eye on changing weather conditions.
Add More Detail
The Vista’s basemap contains lakes, rivers, cities, interstates, national and state highways, railroads and coastlines. Vista H also comes preloaded with marine navigation aids. And, with Vista’s extra 24 MB of memory and USB port, you can download even more map detail with data from Garmin’s entire line of MapSource® mapping products.
Brand new Bushnell Elite 1500 Rangefinder
retails for 400 brand new.Im asking 350
Bushnell is the industry leader in laser-rangefinder technology.
Now meet Bushnell’s leader, the finest laser rangefinder on the planet, the Elite 1500. Accurate from 5 to 1,500 yards. Bright, razor-sharp images. Selective target system. Rugged and impervious to the elements. With the all-weather clarity of Rainguard and an internal LED for low light. Plus a model with Angle Range Compensation (ARC) that accounts for steep terrain and calculates bullet drop. You simply can’t do any better. But you probably knew that by the name.
Features of Bushnell Elite 1500 Rangefinders:
- Built-in inclinometer*
- Bow mode - provides true horizontal distance from 5 to 99 yards*
- Rifle mode - provides bullet=drop/holdover data in inches from 100 to 600 yards*
- Standard SCAN mode
- BullsEye mode
- Brush mode
- Fully multi-coated optics
- Rubber armored
- Twist-Up eyepiece
- Built-in tripod mount
- Carrying Case included
