clearing out parts, will be posting quite a bit more in the next few days. ontop of what i have here i also have a ton of s10 interior parts for 94-97, brake booster/master cyl/prop valve for s10, etc.
gm 3100 coil packs, wires, rockers-all used from a 95 100k miles. used but still worked fine when removed. also have brand new lower to upper manifold gaskets and valve seals. $20
s10 steelie center caps and lug caps. $5
if you see anything of interest let me know. i will let everything go pictured for 50 bucks if you want the whole lot. otherwise things start at $1 dollar
