guys running nitrous - jet questions
I’m using a direct port setup but i can’t find NOS jets in .012 size in a flare jet. i can in a funnel jet. when using the fogger 2 setup can either jet be used? i can’t seem to find any information on this stuff i’m probably gonna end up calling summit about it. i can’t get a NOS jet in a .012 size
well i figured i’d post this up, the difference is the type of line you’re running, the funnel jets need to be used for the steel compression lines, the flare jets are used with AN fittings and braided line.
