head light motor
my friend needs a new headlight motor for the driver side…his car is a 99 t/a
get the brass gear swap
do u have any of those…i told him that i heard guys swap brass gears…he thinks he needs a new motor
http://www.bfranker.badz28.com/headlightfix/index.htm
the gears in the motor are normally plastic from factory. the normally do break, causing the headlight not to move. rebuild kit has brass gears and problem is fixed…
can u get that throw gm?if so part#
im pretty sure you can cause ive done a few, but its been a while. I will check it out for you on monday
