HELP!! 01' NIssan Pathfinder "Load Sensing Valve"
Helping a friend of mine with a brake pedal issue. Its a 01’ Nissan Pathfinder 4x4. I go to help and its clear there is a blown brake line or something of that sort because the pedal goes to the floor.
I get underneath to start looking for a leak and find this crazy-ass junction block above the rear axle with a huge spring and lever attached to it. Fluid is leaking from the seal on the piston/lever.
After spending 1/2 hour online trying to find a picture of this thing I find it to be a load sensing valve.
I can not find the part aftermarket, it may very well be dealer only, but I’d like to get this done asap.
Does anyone know where I may be able to find such a thing?
Google Nissan Part number 46400-8B400. Compare for the best price, looks to be a $100dollar part http://www.courtesyparts.com/images/medium/r50/46400-R50002.jpg
http://www.courtesyparts.com/46400r-valve-assy-load-sensing-pathfinder-r50-02/1997-09/1999-wfed-4wdcal-4wd-2001-wp/4wda/4wd-09/1999-01/2000-p-204143.html
http://www.mynissanpartstore.com/parts/index.cfm?make=Nissan&year=&searchText=46400-8B400&action=oePartSearch&siteid=214102
Thank you so much!
Found one for 98 dollars here. http://www.trademotion.com/parts/index.cfm?searchText=46400-8B400&siteid=214143&year=2001&make=NISSAN&model=PATHFINDER&submodel=&vehicleid=1432945
