Motorola 3bar map sensor in a Omni power honda throttle body mount case. This will replace your stock map sensor and is 100% plug and play. I used it on my turbo gsr set up and no longer need it for high boost. Works perfectly.
$60 shipped
Best map sensor to use for sure. No wiring or anything just 2 bolts and its on. I needed it like that so i could drive on a basemap with stock map sensor to get tuned then swap the map sensors in the parking lot.
take any less ? i can give you money today
let me go check if my air filter works or not, if it dont then u could ship the map n filter together, but i for sure want the map
