As the title states. I have a lot of random parts left over from the millions of hondas ive owned.If you dont see something listed…ask because I might have it.All parts are genuine OEM honda parts off of a car, not aftermarket
Heres the big things I listed:
*2003 acura rsx complete sunroof assembly -$100
*2003 acura rsx all weather rubber floor mats -$35
*2003 acura rsx type s front calipers -$100
*2003 acura rsx front knuckle with control arm, not sure which side- $75
*2001+ honda civic acura rsx gray rear floor mat- $30
*1998+ hunter green acura integra passenger side power mirror-$50
*1994+tan acura integra steering wheel with airbag- $100
*94-01 integra hunter green fuel door- $15
*stock 2002 nissan sentra spec v oem clutch with 100k on it grabs good.-$40
*1998 acura integra gsr intake manifold complete with every sensor-$50
*gray 94+ acura integra rear cargo cover- $75
*2004 honda civic spare tire-$20
*1997 honda prelude spare tire-$20
*1998 civic ex d16y8 exhaust manifold ( small dent on the bottom, works perfectly fine)-$40
*1998 acura integra gsr rear sway bar with links- $80
*1994 acura integra b18b ls valve cover-$ 20
*1994 b18b ls throttle body-$20
*d16y8 civic ex a/c compressor- $30
*1998 civic ex passenger side axle-$20
*acura integra rear view mirror- $15
*1998 acura integra gsr abs control unit- $50
*1998 acura integra gsr under hood fuse cover lid with diagram- $10
*1998 honda civic ex power steering unit-$40
*1996-2000 honda civic under tail light piece (starlight silver)-$10
*1994 acura integra ls power steering bracket-$ 15
*blox fuel management unit-$45
*pair of 1997 honda civic oem headlights, one of the drivers side tabs is cracked off but they mount and work fine-$35
*2003 acura rsx base model oem cd player- $30
- Also have box of random d series motor mounts, transmission mounts. Some B series motor mounts as well.
Most items are best offer. Im not going to sit here and post a million pics of random car parts if your seriously interested in something I will text you pictures of the item.
Any questions post, pm or text me @ 716-949-7620
