HONDA CIVIC 96-00 PARTS CAR WAS 2 DOOR
MAKE OFFER ON ALL PARTS call or text 518-222-5835
ALL INTERIOR HEATER VENTS
COMPLETE STEERING WHEEL WITH AIRBAG AND IGNITION KEY
GREAT STRUTS WITH SPRINGS ALL 4
STOCK 99 HONDA CIVIC ECU (AUTO)
STOCK AIR INTAKE
UNDER THE STEERING WHEEL PLASTIC
AROUND THE STEERING WHEEL PLASTIC
CENTER CONSOL WITH CUP HOLDER (NO ARM REST)
PLASTIC PANELS THAT WENT NEXT TO THE REAR SEATS BUT WAS UNDER REAR WINDOWS THEY HAVE THE POCKETS IN THEM
KICK PANELS
MAIN FUSE BOX UNDER THE HOOD
AUTO TRANNY
VTEC VALVE COVER
GLOVE BOX
D SERIES AXLES
STARTER (auto)
AC COMPRESSER
PASS. AIRBAG
BRAKE POWER BOOSTER
GAS TANK WITH FUEL PUMP
COMPLETE FRONT BRAKE SET UP WITH CONTROL ARMS
FUEL DOOR
AUTO CLUSTER
CLUSTER BEZEL
DOME LIGHT COVER
HEATER BLOWER MOTOR
COIN HOLDER
DOME LIGHT SWITCH
CRUISE CONTROL SWITCH
POWER MIRROR SWITCH
TRUNK AND GAS PULL TABS
ALL SEAT BELT BOLT PLASTIC COVERS
REAR SWAY BAR
SRS
CRUISE CONTROL SETUP
TRUNK PLASTIC
REAR VIEW MIRROR
DASH BOARD SIDE COVERS
POWER STEERING PUMP
COOLANT OVER FLOW
acura integra raditor
acura integra a/c raditor
acura integra auto p75 ecu
acura integra main fuse box (under hood)
acura integra window regulator
da acura integra brake caliper new in box with pads
also have a obd2 to obd1 jumper harness
EVERYTHING WORKED WHEN PULLED OUT OF THE CAR COLOR OF EVERYTHING IS GRAY I DONT KNOW WHAT TYPE OF GRAY
IM SURE I FORGOT A LOT BUT I HAVE 75% OF ALL THE PLASTIC PIECES INSIDE THE CAR I DONT HAVE ANYTHONG FOR THE OUTSIDE
