Can you replace injectors from a 95 civic dx with a d15 with injectors from a 99 civic ex’s d16? Do the part numbers match? Thanks
Part numbers
95 DX = 103130
99 EX = 19559
Looks like they are both Saturated 240cc so I’d say yes
check the part number to the flow rate, and see if its peak-hold or saturated…
would u have to do any spliceing for clips? as far as obd2 to obd1?
You should probably just get a set of 1000’s JAM… especially if you’re looking to make over 120 wheel.
