I’m looking for the following parts:
H22 (manual) engine wiring harness
H22(or civic Si) OBD1 ECU (eventually going with hondata S300 for tuning once I go boosted)
H series Stage 4 Clutch, flywheel, pressure plate
Stock Throttle body with all the sensors (MAP, tps, ect)
Stock fuel injectors
F23 knock sensor (might be the same as H22)
H22 VTEC oil pressure sensor
H22 Coolant and oil temp sensors
H22 thermostat housing
Tial 38 mm wastegate
AEM UEGO wideband
PM me!
Thanks, Frank
