I need to clear out my house. So this will be the biggest list of all the parts I have lying around. If it’s not here I do not have it.
Alll interior parts are black unless noted.
94-01 Integra 2dr parts
94-97 tail lights $40 set
98+ gunmetal one climate control w/ pig tails $25
94-97 black climate control $15
Glove box $20
gauge cluster surrounding $10
rear qaurter window inside moldings $10 set
steering colum lower cover $5
rear speaker grilles $20 set
front seat belts $40 set
rear spoliler led brake light $15
cruise control unit $20
misc throttle cables $10 each (you match up)
rear trunk dome light $5
coin tray r/s $5
green fuel door $5
door strikers $5
door handles inside $20 set
front map lights $15
window/lock relay box $10
dash vent r/s $5
dome light $5
94-97 gauge cluster auto $30
gsr brake booster $20
rear speaker mounts $10 set
under driver dash panel $15
door lock motors/latch $30 set
98+ door harnesses $25 set
door locks/trim $15
door panels $40 set
fuel filter w/ mount $10
climate heat control valve $10
ash tray $10
coolant overflow tank w/ line $15
purple hood some rust $25
94-97 Wings West side skirts and rear lip $150
Sunroof complete $40
B18a head w/ cams $80
B16a cams, 30k $40
B18a block, needs 82mm bore $50
passanger front fender, some dings $35
GSR wing, mint black $75
window regulators (no driver) $20 each
steering wheel w/ airbag $40
steering colums $15
radiator w/ fan and both hoses $60
rear trunk panel $15
misc can mufflers $20 each
Apexi Dunk muffler $40
Blitz dual turbo timer $40
Valvoline VO-16 oil filter $5 have 3
b18 obd-1 distributor w/ external MSD SS coil $80
Sunflower 15" wheels, no center caps $100
tan rear deck cover $25
front door galss $20 each
96-98 Civic parts
headlights $40 set
ditributor $50
P2P EX auto ecu $40
DX Gauge cluster $25
manual window regulators $20 each
door lock latches with rods $20 set
88-91 CRX Parts
1991 Factory oem CRX manual/warrenty/sales books $30
